BCA - Scripting Errors
Under DAS, when a refresh called from a script fails for some reason, the DAS job is marked as ‘Error’ and the Error column shows the relevant error.
Under BCA, when a scripted refresh fails, the job is indicated as ‘Successful’ and the error column is blank.
Is there a recommended way to indicate that a BCA job has failed and to populate the error column on the console?
I have found an undocumented way using some ‘hidden’ properties on the Application object, but am not convinced that this is the way it should be done.
Kevin Charleston
SA Container Depots
Cape Town
South Africa
