i getting this error-message in the bcascdul*.log:
CATCH: cannot import document.
has anyone an idea what i should to do, to avoid this message and force the bca to schedule the jobs ???
anyone out there know what it might be ???
the user right to the bo- and nodes-folders are all write-enabled.
One thing to try is importing the same document to your desktop PC. If that works okay, export it back to Corporate Documents. If that doesn’t make any difference, either schedule it as the user name you used to retrieve it to your desktop (if you didn’t already) - or make sure that the user than originally scheduled the document can still import it from the repos to full client.
