When I run my report I get error message: The following database error occurred:Invalid length parameter passed to the LEFT or substring… SAP knowledge base 2054721 IES 10901 Error INF.
The report works for certain periods but it shows this error when I run it between 2016 and 2017.
The report is based on derived table and the sql query works fine in SQL.
Is there anyway that I can get more details of this error???
Thank you
katis (BOB member since 2018-01-09)
