Bar chart left side
Hi there a need to create a custom horizontal chart with the bars to left side in webi , so a create a bar chart with negatives values (value *-1) so the chart is to left is Ok and display format with negatives values as positives values so Ok. :wink: but I need to fix the values of the chart between -1 and -10 so I try to set this values but the chart return it to the normal state (right side), :frowning:
so any idea or workaround this, e.g. bar chart to left side.
thanks in advance.
You can overlay a positive chart with the negative chart that only the values on the x-axis of the positive chart are visible.
Both charts must have the same min/max values and an exact alignment.
