Bar Chart issue values
issue
Hi BO users, in this case I have a issue with bar chart in webi the display number isn’t complete.
So, I need some workaround for this.
The number five is not complete and the Y labels is the same case.
Thanks in advance.
Is it possible to reduce the font for the labels?
there is a white bar overlapping the 5%
Hi friends, thanks for the comments. The size of font is 9 so it’s better expand the chart.
And the Bart chart is combined column Line.
Testing the issues it reproduce with open the webi report on chrome but it doesn’t in Firefox. :roll_eyes:
did you set the “Hide overlapping labels” ?
did you change/test some other data-value-formatting options to narrow the problem ?
Hi again. I have unchecked hide overlapping labels it’s work’s. So is this possible to wide the bar?
