I am calling a BAPI function module from SAP S/4 HANA into BODS and trying to load the data to S4 HANA.
It works but issue is it writes each ORDER HEADER 3 times with Operation so basically instead of creating one header with one operation its creating 3 HEADERs and each has one operation.
Any help would be appreciated.
I tried changing nesting of source data but BAPI does not like that.
I am giving following 3 tables as input parameters to this BAPI function
- METHOD with 3 Rows (3 Rows, one each for HEADER, OPERATION & SAVE; )
- HEADER (with one data row)
- OPERATION (with one data row)
Here is name of BAPI FM I am using:
BAPI_ALM_ORDER_MAINTAIN
Thank you!
softsys
(BOB member since 2005-05-13)
