Hi there,
How can I avoid a column break? any function ??
Thx
Mile
Mile (BOB member since 2018-03-01)
Hi there,
Thx
Mile
Welcome to B:bob:B!
Can you give us an example?
Nick Daniels (BOB member since 2002-08-15)
thx
have a simple table with many columns that means it stretches over the sides and somtimes will be cut off, that means one part remains at the end of the one page and the other at the side of the next, vertical that is column
In web intelligence, you can change the number of columns displayed
Page Setup
Display
Change number of columns
jemstar (BOB member since 2006-03-30)
