Automation to kill long running reports
Is there any way out to notify the long running reports over defined threshold run time (3-4 hrs) and then kill from BO server. Please suggest.
SDK… or CMC instance manager … or you could make a report using cms driver - the way - just to kill the reports is not very effective because you do not catch the reason… so it will run again according the schedule. better is to pause it and inform the author to optimize it.
