Has anyone started working with the Automation Framework? Specifically with the Change Web Intelligence Source option. I have been trying to get it to work for last couple of months, working on it off and on.
Here’s where I am.
Environment is BI4.2sp8. We upgraded from BI4.2sp4 and so had to modify the base BI4.2sp4 install to add the BI Agent and Automation Framework.
I configured the ActiveMQ Broker to run as a service per KBA 2676566
The default landscape and templates are not created after a modified update installation so I followed the instructions in KBA 2566764 to create them.
I have configured tracing for the BI Agent and Automation Framework by following the instructions in KBA 2588729
I created a simple report that just returns one field against the original unv universe.
I have created a converted copy of the universe to unx format.
I have used the preconfigured template Change Web Intelligence Source & Verify the Documents. All parts of this template run successfully except the Change Web Intelligence Source step which fails every time. I can’t find any log files or other information to tell me why this is failing even though I have the tracing enabled for the BI Agent and Automation Framework.
Has anyone else tried working with this yet and have you encountered similar issues?
I had some trouble getting all the services running initially and used the “Schedule an Expert” option on the SAP Support site but the support person that I got was definitely not an “expert”. Wanted to try my luck here.
