Automation Framework - Change Web Intelligence Source Strategies
Does anyone have an idea of what the strategy configuration is used by the Change Web Intelligence Source functionality in Automation Framework?
When changing a data source manually in Web Intelligence, the default appears to be this:
I would assume that the Change Web Intelligence Source function in Automation Framework uses this same default strategy.
We need to use a different strategy from this and would like to know where to change that strategy if possible.
Yes, the Change Source Task template is using the default strategy and it is not possible to change the strategy. Only solution would be to develop a custom task template.
More details can be found in the Community discussion: https://blogs.sap.com/2017/12/08/automation-framework-concept/comment-page-1/#comment-579198
