Dear Members,
we are preparing an upgrade from 4.2 SP9 to 4.3.
Therefore we are changeing the unv to unx Universes with the automation framework for our WEBI Reports.
While this task works quite well, after the swap of the Universe the WEBI Reports loose their Categorys.
I export a list from the CMS with the categorys before i swap the universes, but it takes a long time to manually set them afterwards.
Any help is much appriciated.
kind regards
