Instead of manually entering description about an object, is it possible to automate this by getting description from an excel file or a database.
If yes, how?
ajq
anushajq (BOB member since 2005-02-22)
If yes, how?
ajq
Thanks for this. However, I am not looking to create my own objects but to automatically extract universe descriptions from the oracle system tables…
You can’t; that’s why utilities like the one above have been created.
Actually, you can. If the tables and columns have help text defined by your DBA and/or database architect, then they should come in with the proper strategy. It’s here in the strategy SQL:
<Strategy Name="Classes_and_Objects">
<Type>OBJECT</Type>
<SQL>SELECT
U1.table_name,'|',
U1.column_name,'|',
translate(initcap(U1.table_name),'_',' '),'|',
translate(initcap(U1.column_name),'_',' '),'|',
U1.table_name||'.'||U1.column_name,'|',
decode(SUBSTR(U1.DATA_TYPE,1,1),'N','N','F','N','D','D','C'),'|',
SUBSTR(U2.comments,1,474),'|',
'O','|'
FROM USER_TAB_COLUMNS U1,USER_COL_COMMENTS U2
WHERE
U1.table_name=U2.table_name
and U1.column_name=U2.column_name
UNION
SELECT
S.SYNONYM_NAME,'|',
U1.column_name,'|',
translate(initcap(S.SYNONYM_NAME),'_',' '),'|',
S.SYNONYM_NAME||'.'||U1.column_name,'|',
'O','|'
FROM ALL_TAB_COLUMNS U1, ALL_COL_COMMENTS U2, ALL_OBJECTS O, USER_SYNONYMS S
WHERE
S.table_owner=O.owner
AND S.table_name=O.object_name
AND (O.OBJECT_TYPE='TABLE' OR O.OBJECT_TYPE='VIEW')
AND O.owner=U1.owner
AND O.object_name=U1.table_name
AND U1.owner=U2.owner
AND U1.table_name=U2.table_name
AND U1.column_name=U2.column_name</SQL>
</Strategy>
However, this will only work upon initial import. If the help comments are later updated, they will not pass through to the universe, it will become a manual process at that point.
Dave Rathbun
(BOB member since 2002-06-06)
That assumes an Oracle DB too doesn’t it Dave?
Yes
It will only work on the first import. If the comment values are added after the tables are included in the universe, then the universe does not get updated. But it’s supposed to work for the initial import. I say “supposed to” because I have never tried it to confirm it. ![]()
Dave Rathbun
Thanks Dave.So once you’ve created the strategy file and how do I use this? What if the database is not up-to-date or empty? Can I use an excel file?
There was a link to a utility hosted here in BOB’s Downloads entered in an earlier post. That’s your best bet.
Dave Rathbun
How does this script works or how make use of Oracel.stg? Because this script is part of that file. My DB is oracle and I am connecting universe thru oracle client. Selecting either of the strategies (Built-in and external), object descriptions are not populated in universe. I am using BO R3.1 SP3
Please help me where I am missing.
Chinnu
chinnu6666
(BOB member since 2007-06-15)
