Auto tabs to be creatred in WEBI
Dear Friends,
I have to create a report , which will display Product wise, Circle wise Revenue. Its a cross tab report.
Horizontal - Product
Vertical - Circle
I have 24 circles. User requirement is, single Tab for each Circle , it means 24 tabs to be created.
Is it possible to create auto tabs for 24 circles.
Like this I have 4 requirements. In other report I have to show city wise, product wise Revune. I have 124 cities.
User requirement is For each tab only one city should be displayed, it means 124 tabs to be created.
Is it possible to create auto tabs for these 124 Cities.
By default 124 Tabs should be created for each City.
Reproting Tool: BO Xi R3
Database: Oracle
assist (BOB member since 2006-04-17)
As far as I know, it is not possible to automatically create TABS. You could consider creating sections instead (if it fits with your requirement) to save the effort of creating so many TABS manually.
nithya_raj (BOB member since 2007-02-03)
