Hi Expert,
i want to auto schedule less then minute. is it possible? if yes how we can?
Kindly suggest.
Thanx a lot
BR
Sultan.
indiansultankhan (BOB member since 2012-08-01)
Hi Expert,
Kindly suggest.
Thanx a lot
BR
Sultan.
The (OOTB) Business Objects scheduler does not accommodate seconds as intervals - only hours and minutes.
The real question is why you would want to schedule a report for less than a minute? You have three threads with questions on scheduling - It might be easier if you can explain what your scenario is, so people may be able to assist?
HTH
NMG
mcnelson (BOB member since 2008-10-09)
Dear Mr. mcnelson;
Actual my client want to update Stock reports as per Actual live data on there ftp server.
or
once any transaction complete in our system (Inbound Or Outbound) then stock should be schedule BO Reports.
so what is possibility I can use.
BR
Sultan
You want to overwrite a file on an FTP server in <60 second intervals?
To me it sounds like you’re trying to use Business Objects in a Transactional sense, a purpose it’s not really designed for.
What else can you do? You have numerous options, it depends on how the data is to be accessed. What happens at the other end - what is using the FTP accessed files as source data? What other options are available? Does the client have access to Business Objects?
HTH
NMG
