Is there a way we can auto purge a document before the deski document is exported to the repository? We are on XI 3.1
Vijay
Vijay K (BOB member since 2004-01-15)
Vijay
Through SDK? It must be possible. If you are using VBA, you can look for the various options that come up when you give “ThisDocument.”
nithya_raj (BOB member since 2007-02-03)
