Auto Fit
Strange to be asking this question. Don’t know if I just did not notice this issue all this time. Anywhoo… I apply auto fit by right click, format, all table cells then, auto fit. This works great. However if I now add another dimension into that table, i need to auto fit that as well. That to me just does not add up. Is there another autofit function that allows a person to interact with a report without having to do those steps… an actual auto fit table function.
honkeyhindu (BOB member since 2007-03-29)
Hi, would someone help me on this issue. I just want to know if its something in my environment or if this is intended BOBJ behavior. I know its a minor item but the client wants to know.
You can tell your client that is how it works. Nothing wrong with selecting a number of columns at a time - maybe you can apply the autofit that way to save time…doesn’t help when you add one more new column though :wink:
Okey…another wish list item…
