I have a universe that requires a prompt for Period and Year. If I want to schedule a report to run each month for each previous Period then I don’t want a user to have to fill in the prompts each time. Is it possible to get the Period and Year automatically filled according to the current date? I tried this by creating variables using the CurrentDate() and then used these in a Format Filter, but I got no data returned. any ideas?
And I can see why the Filter wouldn’t work; It comes after the data has already been selected by the prompts. I can’t set the prompt values in the InfoView schedule because they need to change each month. Is there some way I can amend the SQL to get what I need? I’m no expert, so any help gratefully received.
You’ll need to build relative date objects in your universe. Have a look in [topic=152613]this thread[/topic] for the ones that are for your DBMS.
You’d then build your query condition so that Transaction Date between Start of Previous Month and End of Previous Month, with the two items in bold being the new universe objects that you’ve created.
Is the issue then that the prompts/filters are added at universe/class level such that any queries on the universe/class receive those prompts/filters by default?
Could you change it so the prompts take text, show a LOV of the date converted to string and have the option of writing “Latest” into the prompt such that the universe then translates that out to the latest period?
Sorry Mark P, what do you mean by: “Have a look in [topic=152613]this thread[/topic] for the ones that are for your DBMS”? Where and how do I need to look?
In that case whoever built it is incredibly short sighted if they put default universe prompts in a universe that people are going to want to build scheduled reports off.
