Authentication issue with Open Hub connection
Hi experts,
We have DS4.0 and BW7.5 in our env. The BW open hub destination was setup along with the Data transfer process and Porcess chain. The BASIS admin also configured the external RFC source to DI.
When I import and run the DS job I get the following error,
“When discovering RFC Server DI_SOURCE@CGYSAPD01_BWD_25 at Data Services Administrator
http://CGYDSSS01:8080/DataServices, job server’s web service client has soap fault - Active Directory Authentication failed to log you on. Please contact your system administrator to make sure you are a member of a valid mapped group and try again. If you are not a member of the default domain, enter your user name as UserName@DNS_DomainName”
Is the error referring to the user that the DS service is using?
JeroP :us: (BOB member since 2009-11-30)
