BusinessObjects Board
Auditing of Xcelsius Dashboards with XML Data
I have Xcelsius Dashboards(BOBJ 3.1,XML Data,Oracle database) and want to find out the Audits that how many users viewed etc.,. How can i achieve this?Can i have a universe?
Cristina (BOB member since 2009-02-27)
Depends how you are deploying it I guess. I deploy as SWF on our intranet, so haven’t yet found a way to monitor useage! If you are deploying within Bobj, then the audit universe should tell you, I expect.
Debbie
Correct. The default audit universe in BO will help you there, but only if Auditing is turned on. If it is then you will be able to see who has viewed and refreshed your dashboard.
cdavies :uk: (BOB member since 2005-01-28)
Most of ours are on public-facing web sites, so we take advantage of Google Analytics. Of course, that only tells us who opens the dashboard, and tells us nothing of what they did with it.
