Audit Tables info
Could some one let me know where can i find the detailed info about audit tables
karen (BOB member since 2003-06-18)
Try here , here , here, and the manual for starters. Those threads should yield you some excellent keywords for a BOB search.
thanks
Hi i actually need info about each and every audit table.About table description and columns .
I’d just turn on auditing to the database. That will automatically create the tables for you. Then you can look at them. They are…
OBJ_A_EVENT_LOG
OBJ_A_EVENT_DETL
OBJ_A_APPLICATION
OBJ_A_EVENT_NAME
OBJ_A_OBJECT_TYPE
I may have missed one or two. :smiley:
Look in the Webi Administrator PDF. It contains a list of the tables, their purpose, and (in a few cases) some sample contents. Search for one of the table names that Cindy posted and that will get you to the right area.
Dave
