Hello BOB,
I am searching for answers…regarding auditing items. Please see below, and provide any insight you think can assist me.
Overview:
The audit database has grown to a very large number of records (ie ~22 million), which is hindering the performance on the webi audit reports. For example, we have an LOV that takes FOREVER to run in a webi report because it is hitting the database row-by-row. Currently, I have two resolutions: 1.) Associate LOVs to universe and export them with the universe, and 2.) Apply indexes to the audit database.
My inquiries:
1.) For resolution 1, I have an issue. The associated LOVs are still refreshing in webi when ‘auto refresh’ is unchecked, and ‘export with universe’ is checked. I researched this issue and consulted with a BO Engineer. From what I’ve gathered, this is a bug and will not be resolved until 3.0 fix is applied. Since we will not be getting the 3.0 fix till later this year, I want to find a temporary work-around for these LOVs. Do you have any suggestions?
2.) I spoke to Brian about adding derived tables on the database (rather than in the universe) to assist LOV performance. I assume the LOV performance would substantially improve if we created the derived tables on the database, Would you recommend this approach?
3.) If we are going to apply indexes, I need to communicate with the audit dba on what dimensions will remain static, meaning no new IDs will be added to the database. For example, I want to assume the following fields listed below are static since they are representing actions by the user and we will not be creating new actions. In contrast, Document Name is considered a dynamic object because users will be creating new documents. Can you please confirm my understanding? Also, could you recommend a document that can assist with these types of questions or just understanding the audit database architecture?
Object Name Field
Action Type ID AUDIT_DETAIL.Detail_Type_ID
Action Name ID AUDIT_EVENT.Event_Type_ID
Thank you everyone in advance!
Jdog (BOB member since 2006-05-31)
