Audit is not getting updated
Guys,
I have installed BusinessObjects XI 3.1 version. I have enabled the Audit Database. Initially it was working fine. But now i have found that the Audit Database is not getting updated on regular basis.
for ex, in CMC i have totally 227 users list. But when i have a look on the Audit Database, “BOEAUDITDB” it shows around 150 users only.
Note: If i use SDK i can get the total numbers as like in CMC.
I am using SQL Server 2005.
Please guide me to fix this issue? or Am i doing wrong way?
Thank you in advance.[/b]
sperm (BOB member since 2008-06-03)
Good day “sperm” :shock:
Have you checked the audit events in the CMC? if you are trying to audit some server specific job it must be enabled in the CMC.
-John Vincent
jvmauricio :philippines: (BOB member since 2009-08-03)
Go to CMC->Settings and check the Auditing status, should be ‘Enabled’. If everything is fine there, then CMC-> servers -> CentralManagementServer - Auditing Status -> and check the appropriate events there .
On the other hand, if those ‘missing’ users do not use BOE and had not logged in then everything is Ok.
Antremons (BOB member since 2006-03-21)
[Moderator note - moved to Auditor forum]
Hello Sperm,
Auditing activity will only record the Users who logged in to the Enterprise.
So it is quite possible only 150 users logged in to the enterprise.
-Satish
forgotUN (BOB member since 2006-12-13)
Thanks ‘forgetUN’.
I agree your point. Out of 200+ users, 150+ users only had been logged into the BusinessObjects.
But for your information we are using WindowsAD authentication.
