How to Play Ping-Pong
Ping-pong, also known as Table Tennis, is like the name suggests, to put it simply a tennis table version. It can be played alone or with a partner. This game, in my opinion, is very addicting if you play with people at or above your level. This article will go through all the basic rules of playing table tennis as well as going through some techniques you can use in actual competition. This version of the table tennis table is to use non-compete to the rules will not be strict.
- Or play alone or get a partner to play 1vs1 or 2vs2. The rules will not be different, just the rotation of the ball that the players receive. To make it simple, we’ll go with 1vs1.
You can use any method to find out who will serve the ball first. Once you choose who to serve, that person will play first. Serve by throwing the ball a bit and hitting it. The ball must be returned once on the face of your racket and then be struck to the opponent’s side at least once for it being considered a legal service. If it touches the net but still makes it through, the serve is considered a “give” and you will have to re-serve. You can have as many options as you want in the game. At PingpongClan you can find out the best ping pong table.
After you hit the ball, the opponent will return. For it is considered a legal return, you will have to hit the ball over the net without it touching your face of the court. This continues until a person can not get the ball across the net or hit it off the pitch. This point is then given to the opposing player.
Usually, the game is held until someone reaches 11 points. If both players score 10 points, you can only win the “win-2” rule. For example, if you both have 10 points, then you will need to add 2 more points before your opponent scores, making it 12 to 10.
There are many ways to get points. From a hitting perspective, after serving, as long as the ball ends at the opponent’s side, it is considered a point. For serving, you can hit the ball with a top spin or a slice to make the ball go in different directions with different bounces after the ball hits you.
This is a game that many people like because it is a very easy to learn game but will take years to master. Learn how to play this game and teach your friends how to play.
TVLesson.com is a community-based education for all users. Many different types of how-to lessons can be searched in over 14 different types. We welcome users to sign up and join the TV Lessons community so they can help us grow and refine the TV Lessons experience for the needs of the community. Join us and share your own wisdom and know-how by uploading your video. Many lessons can be found in many different channels. Sharing a lesson can be a great way to connect in the community and to increase your knowledge. All lessons are carefully selected and filtered to provide the best instructional videos. With useful information about ping pong paddle, my article will help you solve your problem.
victornguyen (BOB member since 2018-10-18)
(BOB member since 2008-01-09)
(BOB member since 2003-11-27)
(BOB member since 2002-08-29)
