Attribute setting for a designer
We will be having a person at offshore who will be helping out with The User Module as well as the designer module.
We want to restrict access for the offshore person. He shouldnt be able to export documents and universes. All he should be able to do is work on a local copy of the universe and send the changes onsite so that we can test it here and move it to production.
Are there any standard attributes that we need to restrict for such kind of offshore work ?
Any help is welcome.
Ashish
Yep, in Supervisor, select the user and then double-click on the Designer icon in the right pane. This will bring up the Command restriction dialog. Under Universe, you can turn off Export Universe. Do the same for BusinessObjects - under Document, turn off the Send Document… commands, etc.
Hope that helps.
Paul
Ashish
If you haven’t done so already, within Supervisor Module select the user then double click on Designer from the configuration tab, you can disable the export to universe attribute from there. do the same as above for Business Objects and disable export universe to repository attribute and any other attributes you want to disable etc.
Minal :slight_smile:
designer module.
Ashish
I do know…how it is done…i just wanted a list of things to be disabled…do u have one ?
Ashish
