Another thing to remember, Depending on where the 20 sub-reports are (Page Header, Group Header, Detail, etc.). They may be called multiple times (especially at the detail level). This can greatly affect performance.
And each time a subreport is rendered, it does it’s own query to the database. Subreport processing happens in pass 2 of the report processing.
Are you using “Page N of M” or “TotalPages” in your report? If you are, try removing it because that will make the report run faster as well. When you use either of those, Crystal has to render ALL of the pages in a report before it can show the first one. If they’re not used, Crystal will render a page at a time, which means that each of the subreport queries probably won’t run until the page where the specific subreport starts.
When I was working for Crystal I ended up writing a UFL that built a text file based on the processing sequence of a report (results were confirmed by the dev team).
A report renders top to bottom, section by section and will process objects in the sequence that they are placed in the section (not the sequence that they actually appear), but subreports run last. Subreports will process in the sequence they were placed too.
Like Hilfy says, removing page N of M will help as it then invokes page on demand and only renders the pages you request.
Crystal will send SQL statements concurrently too (if it can!).
