When I try to access the admin page (wiadmin) i am asked for java authentication, but others are not getting this error.
BO 6.5.1 is installed on Windows 2003, IIS6.
I compared the browser settings in IE-8 - it is all the same.
Any ideas?
As soon as i key in the admin console URL, i see a java app running, and then i am prompted for credentials, If i key in the credentials, I am able to see the login page. If i cancel the authentication, i see the error message as
ClassNot found Exception -> bo.wi.adm.FrontalApplet.
When I navigate to the folder and look for that class, I see that. (obviously).
In teh java console I see -
Java Plug-in 10.4.0.22
Using JRE version 1.7.0_04-b22 Java HotSpot™ Client VM
I think it is something to do with the permissions and or java jre settings.
Please help!
User@BO (BOB member since 2012-07-23)
