I need to load data monthly wise to hana database using BODS. For this job condition is if
New records---- Append.
Existing record — delete and Insert.
The Target table is also used in other data flow with bulk load with append option.
Please let me know how I can achieve this requirement.
Merge incoming data so you just have the single dataflow controlling what data is added/updated/deleted in the target table, or if not possible prevent the two different dataflows loading the same target table at the same time[/list]
