Is there any way to make document descriptions wrap, in the InfoView document list display?
I discovered that if I put hyphens in the document description (in Properties), new lines display in the document list description starting with the text following the hyphens (and the hyphens display at the ends of preceding lines). I am using this workaround, but it makes the descriptions look odd and they don’t behave well when windows are resized, and they look even stranger in the tooltip!
See my screenshot.
sruggero
(BOB member since 2007-10-20)
