Any way to edit an existing universe?
In our BO setup, we need to do some periodic maitenance activities for some of the existing universes. This is kind of creating new classes, updating some objects and deleting some classes/objects.
So we were thinking of using the VBA to automate this. Is this possible using a VBA?
If yes, any pointers about how to do this?
If No, any other way to do this?
Your opinions will be highly appreciated. :!:
smartvnr
smartvnr :india: (BOB member since 2003-09-24)
Yes, this is possible using VBA
refer sample code from BOB
https://bobj-board.org/t/24722
Shahubar Sadiq :india: (BOB member since 2003-02-28)
Hi Shahubar,
Thanks for your response. Is there any way to copy-paste existing objects/classes etc?
  • smartvnr
There is no copy paste in SDK,
Read the classes and objects through loop or specific object then Add those objects with different names
I am trying to export the universe using VBA…
'exporting the universes...
    universes.Export("Universe", "Company", my_unv.Name, 0)
But this statement is throwing following error:-
Any pointers… ?
  • smartvnr
It’s a VBA syntax issue. Add the Call keyword in front, or remove the parentheses. Either of the following should work:
Call universes.Export("Universe", "Company", my_unv.Name, 0)
universes.Export "Universe", "Company", my_unv.Name, 0
A discussion on the applicable VBA syntax, and options can be found here.
that worked! :mrgreen:
  • smartvnr
You’re quite welcome …
