Any solution for this
I have a universe file .unv, imported from other CMS,(i dont know the name of the CMS)
now when i am trying to open in my system it gives the message (attached img).
is there any solution to this.
BOB_newbie (BOB member since 2009-10-24)
hi!
it’s saying that the universe that you are trying to import is in other CMS. connect to the CMS where the universe is located and there you can alraedy import it. you can see the CMS name when logging in to Designer.
regards,
r.A.
R.A. :philippines: (BOB member since 2008-10-28)
(an oldie but goodie!)
r.A is right about the message - also…
Here are some workarounds however that might help:
Opening universes from another CMS
Deleting universes and subsequent problems
