Another vague question from me... Slow Universe
For a universe, you cant really scan / repair via BO… you consider doing an export / import of that domain’s owner? If you feel adventurous, you can export, drop, and then import the universe tables (or the whole user that has that schema).
If you do, verify the initial table size, next extents, etc… I don’t particularly like the defaults import uses…
Just a (scary) thought,
Brent
  • multiple repositories isn’t necessarily bad (or good, I guess)… we
    have 3 universe domains, multiple doc domains…
Export
We have three repositories (our first mistake :slight_smile:
One troublesome universe exports VVEEERRRYYY slowly (we’re talking 15 - 20
minutes) to two of the three repositories. We have no problems with any
other universes or with that universe on repository number three.
Does anyone have a suggestion. We’re stumped and willing to try virtually
anything.
We’ve done a scan/repair/compact etc. on all three repos.
Cindy Clayton - Business Objects Consultant AT&T
336.698.2144
Give people more than they expect and do it cheerfully. Talk slowly but think quickly.
Smile when picking up the phone. The caller will hear it in your voice.
Mind your own business.
Learn the rules then break some.
Judge your success by what you had to give up in order to get it.
