Another SSO Problem
BOXI system
-server Windows 2003
-IIS with infoview.NET
-CMC on WACS
-authentication windows AD - Kerberos
-CMC on wacs, authentication Windows AD without SSO work fine on the serveur and on a client machine.
-Infoview.NET, authentication Windows AD without SSO work fine on the serveur and on a client machine.
Problem
Infoview.NET, authentication Windows AD with SSO work fine on the serveur but not work on a client machine and can’t login with windows AD credential. Track with wireshark and when SSO is activated , Infoview.NET try with NTLM , what the .
Anybody can help me ?
slimerracer :canada: (BOB member since 2008-03-31)
There’s been some recent posts about a MS-Security Patch breaking SSO on the desktop if you are using IE.
Try looking some of them up - or using a non-IE browser to test from the workstation.
MJRBIM :canada: (BOB member since 2007-03-23)
