I have a problem with a complex report. To make it simple here I am providing a sample data to replicate my problem.
The report should look similar to the following
DIM MEAS1 MEAS2
Val1 10 0.1
Val2 20 0.4
Val3 0 0
Val4 30 1.0
TOTAL 50 0.25
Where,
MEAS2 = MEAS1 / MEAS3
Here I am giving sample values for MEAS3
DIM MEAS3
Val1 100
Val2 50
Val3 20
Val4 30
TOTAL 200
The user wants to eliminate the 0’s in the report, so I had to rely on the Rank function (a neat trick given by Dwayne/Dave- here
I cannot use the filters as the Measures are all complex report variables across different data providers and BO do not allow aggregates in complex filters)
Coming to the problem, I have the report exactly the way I wanted; the only problem is that the TOTALS are not the same for MEAS2.
The result looks like this:
DIM MEAS1 MEAS2
Val1 10 0.1
Val2 20 0.4
Val4 30 1.0
TOTAL 50 0.277
The total for MEAS2 should be 0.25 (= 50/200) but the value I am getting is 0.277 (=50/180).
Obviously, it is eliminating the Value of DIM Val3. I need that value to be included in the calculation.
I tried to use the extended syntax, but that value is not coming into the table. I used NoFilter(MEAS2), IN(DIM), FOREACH(the report has sections) , FORALL(DIM), In Block; but no result!
So I want to know can we get the filtered value (eliminated using Rank function) into the calculation using extended syntax?
I appreciate any suggestions on resolving this problem.
multicube (BOB member since 2005-09-28)
