BusinessObjects Board
Alerts on a Combination Chart
I have created a Combination Chart, but cannot select the enable Alerts fuchion…
Can any advise me, what maybe the issue here
paul.raeburn (BOB member since 2010-03-05)
Alerts won’t work for all the chart types… could you check with any other chart type ? is it not working only for combination charte… it seems that combination chart will display in small lines… so there may not be an option of alert for this…
surya.g :india: (BOB member since 2009-11-24)
yes I have tried this on other chart types and it works… but why does the alert type properties show enable when you use a Combination Chart?
You can set an alert if you use one series only (as a column).
As soon as you add another series, the alerts will disappear.
wimvg :belgium: (BOB member since 2010-02-12)
wimvg,
thanks for your reply… your answer indicates that Combination Chart cannot use alerts…
Hi paul
Alerts for combination chart doesnt work so,
1.Create a column chart and line chart (for trend line) individually , 2.overlap them ,
3.disable backgrounds for both the charts.
3.give alerts.
This is the easy way to reach your requirement.
kencha (BOB member since 2010-05-11)
Good idea Kencha,
I have same problem than Paul !
Thank you.
CMULLER :fr: (BOB member since 2004-12-17)
Eventhough the user guide states something totally different:
"3. Select Enable Alerts.
Note:
  • For charts with multiple data series, this option is only available with the combination chart."
I’m confused to say the least…
RGreen (BOB member since 2011-06-09)
Xcelsius 2008 - Combination Charts and Alerts do not work (tested with SP3)
Dashboard Design 4.x (AKA Xcelsius) - Combination Charts and Alerts do work.
cdavies :uk: (BOB member since 2005-01-28)
