alert sign on scorecard not showing
probably a stupid question, but I can’t seem to get the alert signs visible in my scorecard component
I can see if I check the “sign” column in the Alerts section that a white space is placed before the values, but the green and red lights do NOT show (in front of the values.)
see printscreen for exact details.
What am I missing? why doesn’t this work?
Tiny :netherlands: (BOB member since 2004-11-10)
You need to let the component know where the Alert Values are located. Bind the Alert Values (just above the “As Percent of Target”) to your column F in your example and it should work.
Good luck,
Roxanne P
Sr BI Consultant
InfoSol, Inc.
RoxanneP :us: (BOB member since 2006-08-07)
thanks, that did the trick!
BTW
funny why it needs extra guidance to now where the values are located… you should think this was transferred from the general properties tab
I agree, it does seem that it should use that by default. However, there have been occasions when I have used the scorecard to display text information, but wanted alerts to show up as well, and in that case I had to have values in different cells from the scorecard, so I was glad I had that option!
~Roxanne P
Sr BI Consultant
InfoSol, Inc.
