Aggregate by sum _and_ by avg
Greetings to all!
In the company where I’m employed we’re facing a problem involving (I think) both Designer (5.1.3) and WebI (2.6).
Here’s the problem.
In the universe we created we want to define a misure which should be aggregated by sum or by average depending to the dimension.
Is there any way to do so? Maybe with a later version of Designer and/or Webi?
Franz
franz (BOB member since 2004-08-05)
Welcome to BOB:
A) Please, do not cross post, one post is enough (I deleted all the other duplicate posts)
B) To answer your question: No, you will have to create separate universe objects.
