I have defined two aggregate aware objects as follows
@Aggregate_Aware(CASE_TYPE.CASE_GRP_CD,CDM_DIM_CASE.CASE_GRP_CD)
and
@Aggregate_Aware(CASE_CATEGORY.CASE_CATGRY_CD,CDM_DIM_CASE.CASE_CATGRY_CD)
As you can see the two objects first select columns from two higher level tables ,namely CASE_TYPE and CASE_CATEGORY.
However as per aggregate awareness, the second option is to select the column from a low level transaction table called CDM_DIM_CASE. Both objects refer to this same transaction table at the lower level.
The objects work perfectly if I use them separately for separate queries. They will select the objects from the higher CASE_TYPE and CASE_CATEGORY tables when I use them separately.
However if I combine both objects in the same query, suddenly they start referencing the CDM_DIM_CASE table which is lower in the aggregate aware hierarchy. However there is abolsutely no aggregate aware settings between these objects which would cause this to happen. Eg:- When I select the above two objects, the following code is generated, even though the CDM_CASE_TABLE is second in the aggregate aware matrix for both objects
SELECT
CDM_DIM_CASE.CASE_GRP_CD,
FROM
CDM_DIM_CASE
When I select these objects separately, they select the correct table according to the agrgegate aware matrix
SELECT
FROM
CASE_TYPE
and the other object generates
SELECT
FROM
CASE_CATEGORY
I have narrowed down the issue as follows. if you have 2 aggregate aware objects in which the lower level of the aggregate awareness matrix points to a single common table, the query generated seems to refer the single low level table, rather than joining the two high level tables as had been specified in the aggregate aware matrix
Please help
[Moderator Edit: Added code formatting - Andreas]
AmalkaWijayaweera (BOB member since 2009-07-16)
