After upgrading to 4.3 SP2 Patch 7 Something went wrong. If the issue persists, log out and log in again
After upgrading to 4.3 SP2 Patch 7 Our end users keep getting this error pop-up. ‘Something went wrong. If the issue persists, log out and log in again’ There is one Kbase https://launchpad.support.sap.com/#/notes/3223331 We did try this and ended up having to do a full restore. Our systems are on Linux 8.4
After looking around this could be a browser issue. I’m not sure yet. Has anyone else ran into this issue?
BW
In which cases are you recieving this Error message?
when creating a webi?
please explain. I have tested SP2 Patch 700 for a month and seems to work well on windows.
It happens anywhere in the launchpad area. I have noticed that if I sit idle for about 5 minutes the error pops up. You just click on okay and keep going. It’s more of an annoyance than anything else. Only our client side is on Windows. All the servers are Linux.
maybe you can clone your server in a separated network, and perform a repair as the note says. if works, then do the same in production.
As I said, I’m not having this EM on my installation on windows servers.
regards…
​This was the issue.
Cross-Origin Request Blocked: The Same Origin Policy disallows reading the remote resource at http//*
Here is the fix. 2837725 - java.lang.RuntimeException: Error initializing storage when trying to login onto fiorified launchpad | SAP Knowledge Base Article
Solution 1
