you have to check with your Admin whether you have right to create report or not, if not you have to enable create document feature
CMC --> Application -->web intelligence --> user security --> ADD principal —> (select your user name) --> add and assign security --> Advanced --> add and remove rights --> web intelligence -->Application --> (check create document box)
