Adding Previous balance to current balance
I am trying to create a a cross tab report which displays the current balance which is made up of the previous month balance.
A 10
B 5
Balance= A-B + Prevuious Months Balance
I have tried using, Previous Month Balance=if(month=previous(month);Balance) and add this to the current balance, but to no avail.
I have attached a spreadsheet explaining the cross tab I am trying to create.
Many Thanks
Pre Month Balance.xls (24.0 KB)
nicktucker :australia: (BOB member since 2006-03-09)
The example is a bit ambiguous - what are your measures and Dimensions?
Thanks for your reply.
In my example, Inventory, PO and Sales are measure objects, where Balance is the calculation as stated, PO-Sales+Previous Months Balance.
Create an object Balance at report level with definition as =[PO]-[Sales]
And in the report for Balance coloumn place the formula as =RunningSum([Balance])
See if this helps you
saurabhg :india: (BOB member since 2007-04-02)
That worked :stuck_out_tongue: , I should have tried that, over complicating things again.
Many thanks for your help on this.
Kind Regards,
Nick
