AddIn with BCA 6.5.1
Guys,
We are testing the 6.5.1.
Only one blocking issue for the upgrade persists.
How to parameter the server to use and AddIn (.rea file).
I did the exact same procedure as for V5.x but the BCA still returns the same error “(20) Bad macro name”.
Any ideas?
Sucec (BOB member since 2005-08-04)
I just found the modifications to apply in the REGEDIT.
Thanks to the Bob’s FAQ: FAQ: Broadcast Agent Scheduler / Publisher
Only one thing to change in it, is the Regedit adress:
Just replace:
\HKEY_LOCAL_MACHINE\SOFTWARE\BUSINESS OBJECTS\BUSINESSOBJECTS\5.0\BUSOBJ GENERAL PREFERENCES\BUSOBJ\OPTIONS
with:
\HKEY_LOCAL_MACHINE\SOFTWARE\BUSINESS OBJECTS\Suite 6.0\default\BusinessObjects\BUSOBJ GENERAL PREFERENCES\BUSOBJ\OPTIONS
With the next steps all work fine!
