Add syntax to start of sql statement
Hi there,
I’m after a way to add syntax at the beginning of each sql statement, similar to the universe parameter “END_SQL” that allows syntax to be added at the end of each sql statement.
Any ideas?
:confused:
Fulcher (BOB member since 2005-05-10)
I used to have to define Oracle hints at one stage and the only way was to define objects with the code. They had to appear 1st, so I made the users select them as the 1st object for all queries.
I don’t know offhand of a way to automate this generically.
I wonder if you could alter any of the prm/ora/rss files that handle the syntax specifics so that you change the Select command?
