I am working to solve an issue with users attempting to login to InfoView or the CMC on an XI 3.1 server running Tomcat 5.5. The error is as follows:
“Account Information Not Recognized: Active Directory Authentication failed to log you on. Please contact your system administrator to make sure you are a member of a valid mapped group and try again. If you are not a member of the default domain, enter your user name as UserName@DNS_DomainName, and then try again. (FWM 00006)”
I have added the debug=true to the bscLogin.conf, and there are no entries in the stdout.log file. I added -Dcrystal.enterprise.trace.configuration=verbose to the Java options and do not see a jce_verbose.log in the profile for the service account.
I can login using Designer or DeskI without errors.
The OS is Windows Server 2008 r2 and the browser is IE7.
I could use some suggestions with this one, please.
I had already done the search and read that thread, and many others to boot.
I did finally find the problem and it was simply that initiate is not spelled “initate”. It took me almost 24 hours to notice that the third “i” was missing, and I even had several other people review it because I thought it might be a typo or something.
I hear you there. I have a complete document with all the steps and code needed so that I can CnP it. However, due to security constraints I was forced to access the server in a way that the clipboard was not linked and I had to type everything. The krb5.ini was a bear to make sure it was accurate.
Of course the short file that never changes? Yeah, that was the one I typo’d.
