system
August 14, 2008, 1:28pm
1
We have installed Auditor and is configured properly and is recording data into the XI R2 SP3 Audit database (Oracle).
When I look at the Activity Universe , the derived tables in the universe have issues with the SQL Syntax defined to create them. I was able to fix the SQL in the following derived tables
Derived_Session_id
2)Derived_Object_Name
3)Derived_Universe_Name
4)Derived_Document_Name
5)Derived_Viewed_Report_Name
Derived_Objects_Type
But have been challenged with the SQL Errors in the following derived table
7) WA_SESSION
Has anyone encountered any errors with the WA_SESSION derived table SQL in the Activity Audit Universe in XI R2 (SP3) ??
EnterpriseArchitect (BOB member since 2006-03-23)
system
August 14, 2008, 1:53pm
2
I’m very surprised at this, I thought the install, when you selected your platform would have taken care of this for you.
I have never had any problems…
What SQL syntax did your derived tables contain, MS SQL, Sybase?
Mak 1 (BOB member since 2005-01-06)
system
August 14, 2008, 1:54pm
3
My guess is SQL Server.
system
August 14, 2008, 1:57pm
4
Our installation is MS SQL.
What are the bits from that table that you are having trouble converting to Oracle?
Maybe, I can help?
system
August 14, 2008, 1:58pm
5
Ive implemented this at few sites on top of SQL Server both from the install and a "manual" install from cab29 and havn
t had any issues.
Just had a look at the one Im using at the place I
m at at the moment and it works ok (SQL Server 2005).
What was wrong with the SQL specifically?
ABILtd (BOB member since 2006-02-08)
system
August 14, 2008, 2:00pm
6
Its SQL server syntax, his installation is Oracle… .
Maybe BO haven’t heard of ANSI 92… .
system
August 14, 2008, 2:01pm
7
Hold on.
I just fully read your post.
If you have a look in Cab29 on the BOXI install disks all the BIARS that contain the Universes and Reports are on there. You should find a specific one for Oracle and not have to change anything.
system
8
We are using Oracle here for the Audit Database and the WA_SESSION derived table has Oracle Syntax Errors.
Would you by any chance have the SQL used to create the WA_SESSION Derived table (Edit Derived Table) in the Activity Universe on Oracle.
system
August 14, 2008, 2:03pm
9
Andys saying load the Oracle version of the universe, from a cab file, the syntax will be correct for the derived tables in this one…
system
August 14, 2008, 2:06pm
10
Just check CAB29 for you.
File name is
auditing_db_oracle.biar.65FF9700_720A_4759_AB8C_5E33BA2E32D3
Just import that with Import wizard, it`s got the Universe and Connection in it.
system
August 14, 2008, 2:12pm
11
Also, I’m interested how the wrong universes were installed in the first place.
I would have thought that when you installed selecting the Oracle platform for your CMS and Audit DB’s would have been enough.
Or have you changed platforms?
system
August 14, 2008, 5:26pm
12
Thanks for all your help !! I have restored the orginal Activity Universe file from M29.cab file and things are working fine now.
system
December 9, 2009, 4:36pm
13
how do you import auditing_db_oracle.biar file? I tried with the import wizard but it shows nothing to import, so the universe can not be used with Oacle DataBase?
I precise we took the biar files from the instal cd provided by BO.
regards.
cyril365 (BOB member since 2009-12-09)
