Ability to customize KPI's on dashboard
Hello to All,
Our client has a need where after logging in to BO, he wants to have the ability to customize KPI’s. Eg if there are 20 Key Performance indicators, he wants to be able to have checkboxes next to each of these. Then upon selection of checkboxes he should be able to look up dashboard and reporting data for those particular selected KPI’s.
Is something like this possible with Business Objects. We are looking into Dashboard Manager and also Xcelsius but dont know if this is possible. Can this be achieved by some java coding…
it_guru_2006 (BOB member since 2006-10-31)
hi:
Please design the .jsp screen for customization…
vasanth (BOB member since 2008-06-05)
I found that a member asked same question in this forum some months ago.
Pls use search box to find this questions with comments
If you want to get more materials that related to this topic, you can visit: KPI
Best regards.
johanelmander457 (BOB member since 2011-03-21)
