ABAP code Transporting from Dev-->Quality-->Production
Hi Experts,
Actually we are using Rapid Marts(SD) in sap bods 4.1. So here we have a source is SAP ECC and target is MS SQL Server 2008. Thing is how we can transport the ABAP Code from Development to Quality and to Production. Can any one give me the solution for the above query.
I would greatly appreciate your help.
Thanks & Regards,
Sudheer
Sudheer Kodimi (BOB member since 2013-03-29)
If Quality and Production are closed for ABAP Chances( generated by BODS),
you will have to take the .aba files generate on DEV Application Server. You will have to run in Generate and Execute mode for this. And then provide the set of .aba files to tbe basis to put into a CTS and then import it to Quality and PRoduction.
Once in Quality and PRoduction, change it to Execute Preload Mode.
If not if you credentials directly generate .aba by right click on the abap dataflows.
Regards.
SantoshNirmala :india: (BOB member since 2006-03-15)
