A subprocess in the processing serer was forced to terminate
occurr the follow,
this errors are present when run desktop intelligence report
A subprocess in the processing serer was forced to terminate. (RCIRAS0622)
A failure occurred while the server was processing report ‘REP-AC-012 TXN MOVEMENT REPORT’ (id=3214) for user 1157 (RCIRAS0567)
I don´t found any information about it,
who can hep me? :frowning:
please
Marlenis :panama: (BOB member since 2008-10-15)
Hi and Welcome to B:bob:B!
I moved your topic from Off Topic to the Desktop forum.
Chris Pohl :us: (BOB member since 2002-06-18)
Did you find soulution for this error
KhoushikTTT :us: (BOB member since 2005-02-24)
We also see this issue - was a solution ever found?
matt1306 (BOB member since 2005-08-09)
We also have this issue on BOXI R2 SP1 ? Does anyone have a solution/advice ?
Cheers,
Gary
gary_scott (BOB member since 2004-12-17)
Search for Note id 1319409 on SAP Notes database as it deals with RCIRAS0567 errors in R2 environment.
I am facing similar issues in Crystal Reports processing in XI 3.1 environment but don’t the recommended solution applies to this version.
Farhan Jaffery :us: (BOB member since 2005-08-27)
I tried to look up that Note: 1319409 but the SAP Notes system does not have a descent search engine. What does the note say?
cb2SD (BOB member since 2006-08-17)
