i have installed the bo 6.5 i need to see the infoview
can anybody help in this
Arif
idarif2007 (BOB member since 2010-06-03)
Arif
[Moderator note - moved to appropriate server forum]
Nick Daniels (BOB member since 2002-08-15)
Hi Arif,
After installation, did you used Configuration Tool to deploy the InfoView web application?
If yes, you will know the URL to access the InfoView.
nicholas (BOB member since 2008-07-31)
thanks for the reply
can u detail me about the configuration
Arif
You might not be getting many replies because this is a really old release you’re trying to deploy … it’s also no longer supported by the vendor … which begs the question: why are you deploying such an old release?
The configuration tool is available from the Start menu on the server:
START > PROGRAMS > BUSINESS OBJECTS > CONFIGURATION TOOL (or something like that)
Chris Pohl (BOB member since 2002-06-18)
