4.0 SP5 dswsbobje Web Services on Tomcat 7
We are experiencing this issue when listing the web services on Tomcat 7. We use SAP BusinessObjects 4.0 SP5
https://<web_server>:8443/dwwsbobje/services/ListServices
SEVERE: Servlet.service() for servlet [AxisServlet] in context with path [/dswsbobje] threw exception [https is forbidden] with root cause
javax.servlet.ServletException: https is forbidden
We tried a number of SAP Notes with no result.
Tried this workaround and no success
Looking for suggestions…
Nicolas Hadj-Blaha :new_zealand: (BOB member since 2005-03-10)
We experienced it in SP6 (moved from SP4 to SP6). Did you resolve this yet?
alexks (BOB member since 2008-03-25)
We have just tried upgrade from BO4 SP4 to SP7 on UNIX and default Tomcat.
Got stuck with the same problem.
ADAPT01634294 fix does not work :frowning:
Best regards,
Mike
mike_k (BOB member since 2006-08-18)
All,
Seems like I got the solution.
It is a variation of http://service.sap.com/sap/support/notes/1927235
  1. stop tomcat and BO services
For both files:
/tomcat/webapps/dswsbobje/WEB-INF/conf/axis2.xml
/tomcat/webapps/BusinessProcessBI/WEB-INF/conf/axis2.xml
ensure that you have the following code for transportReceiver in
section.
Both HTTP and HTTPS should be there, and should not be commeted out :slight_smile:
(the SAP article suggests to replace the
8080 8443
I have noticed that it is extremely easy to leave there some obsolete closing “/” or make other mistakes :slight_smile:
  1. do not change the *.wsdl files in tomcat\webapps\dswsbobje
    as oposite to indication from http://service.sap.com/sap/support/notes/1927235.
  2. Clean all the content of the tomcat/work/* folder
  3. start BO services
  4. start tomcat
Weird but works :slight_smile:
Hope it helps.
Mike
