2LIS_11_VAITM ISM fields of append not visible
All
I’m facing an issue with a (according to SAP) released ODP extractor, 2LIS_11_VAITM.
In the ECC source system, it shows all required/expected field (tested via RSA3).
However, when imported in DS, some fields, specific to an IS-Media append (JSBW_SD_VEDA) are not. (eg field ISMVKUESCH)
Anyone else had similar behavior. If so, how did you fix this? We already re-activated the extractor, to no avail.
Any help would be greatly appreciated, thanks!
ScSi :belgium: (BOB member since 2013-10-08)
